I have decided to replace the wiring harness going to the back of my car, instead of trying to splice new wires in, where mine shorted out and melted... My question is, is there a plug where the rear wiring harness terminates under the dash? I'm going to have to pull the harness out of the trunk into the back seat area to get to the part that I need to replace anyway... Figured I would just go get another harness from the junkyard... IF it is not a nightmare under the dash! Another question about this wiring harness... This is the harness that runs down the driver side of the car.... this harness is only for the tailights etc right? (No fuel pump, speakers etc?) I don't have a wiring harness schematic, So I need to see if those are part of this harness... So I know what i'm getting into! If it is just the tailights, trunk lock, etc... it should be pretty easy to do.
Wiring harness question
http://www.tomspolicecars.com/Tags: None
I have a 1990 evtm I can scan for you, but I am not at home right now. Could have it by tomorrow if that is oksigpic
Cool that would help alot... I won't be able to work on it until at least Tuesday anyway... thanks
Originally posted by trwp72 View PostI have decided to replace the wiring harness going to the back of my car, instead of trying to splice new wires in, where mine shorted out and melted... My question is, is there a plug where the rear wiring harness terminates under the dash? I'm going to have to pull the harness out of the trunk into the back seat area to get to the part that I need to replace anyway... Figured I would just go get another harness from the junkyard... IF it is not a nightmare under the dash! Another question about this wiring harness... This is the harness that runs down the driver side of the car.... this harness is only for the tailights etc right? (No fuel pump, speakers etc?) I don't have a wiring harness schematic, So I need to see if those are part of this harness... So I know what i'm getting into! If it is just the tailights, trunk lock, etc... it should be pretty easy to do.
I would recommend that you just get the portion of the donor harness for whatever you fried and run that from front to rear. You will save yourself time, blood and sweat...
What exactly did you fry?
Good Day,
I just finished 75% stripping a 1990 Lincoln Mark VII. Yes I did cut the wires at different point. If there is something you need and can handle the condition let me know. Cover shipping and were are good.
Goal is/was to keep any thing usable on my 1989 MGM and help the world with items left over.
Thank you,
Ringting
