This morning when I fired up my car, my air bag light continued to blink slowly, until I cycled power. I assume it's a code for something. Thought perhaps my air bag failed a check on startup.
Air Bag Light
If it went away, you have an intermittent problem. Generally they flash codes the same way that the check engine light does when you pull codes. Blink blink blink....blink blink
32.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 91waggin View PostIf it went away, you have an intermittent problem. Generally they flash codes the same way that the check engine light does when you pull codes. Blink blink blink....blink blink
32.
1991 CV LTD LX Stock 5Xk
my 93 does that occasionally... system bitches about the safety switch. jiggled the harness and it's played nice since (almost a year now).
Originally posted by Morris View PostSo what I need to do is count them, and see what I come up with, eh?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
is there a way i can do that code search on a 1983 grand marquis with cfi.
Air Bag LightOriginally posted by MattsGrandMarquis View Postis there a way i can do that code search on a 1983 grand marquis with cfi.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Find me an 83 Grand Marquis with an airbag, and I'll tell you how to get codes out of it.86 Lincoln Town Car (Galactica).
no i am talking about just a self test to make sure there are no codes stored in the ecm. Not an airbag test. i know my car wasnt available with an airbag. i dont know where to buy a eec iii test tool for the lousy plug there.
2 - All Primary Crash Sensors Disconnected.
3 - Air Bag Deployment Circuit - Low Battery Voltage or Low Backup Power Supply Voltage
4 - Safing Sensor - Diagnostic Circuit Open or Low Primary Crash Sensor Resistance
5 - Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
6 - Driver-Side Air Bag Circuit - Open or High Resistance
7 - Passenger-Side Air Bag Circuit - Open or High Resistance
8 - Primary Crash Sensor - Not Mounted to Vehicle Properly
9 - Primary Crash Sensor Circuit - Open or High Resistance
10 - Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by MattsGrandMarquis View Postis there a way i can do that code search on a 1983 grand marquis with cfi.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by MattsGrandMarquis View Postno i am talking about just a self test to make sure there are no codes stored in the ecm. Not an airbag test. i know my car wasnt available with an airbag. i dont know where to buy a eec iii test tool for the lousy plug there.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by pantera77 View Post2 - All Primary Crash Sensors Disconnected.
