power door locks? one is operational but slow
    Hi!
    Will have time this Sunday to take open the panel and have a look, but basically:
    When I hit the master lock switch, all the door locks go ka-chunk, except one-- the right rear door. At first I thought it was completely broken, then I realized that if I hold down the switch, it locks itself, just at a several-seconds' snail's pace.
    It unlocks, however, just as fast as any of the others.
    I learned that door locks are (electro)magnetic locks, using solenoids to pull down?
    Do they use a spring to come up?
    Here's where I'm going with this: one possibility is that there's something rubbing against it in the door, so it's fighting more resistance. But if it's spring loaded, wouldn't it be slow to unlock too? Or perhaps not, anyway?
    The other possibility is that theres a problem with the solenoid itself, or in the wiring to it. I can certainly check for 12.5V.
    If some mechanical interference within the door panel would likely cause it to BOTH slowly unlock and to lock, then I might just buy a new lock solenoid before I get into it on the expectation that it will need to be replaced, so that I don't find myself driving to the parts store with an unlocked, torn-apart door
    Has this happened to your car, and what did you find out?
    thanks!!
    -Bernard
    The actual unit it sorta funny how it works. The rod (that connects to to latch mechanism) is actually threaded and the inside of the motor spirals up and down that thread rod pushing the rod up, or pulling it down. The location that it is in (tucked up right against the door skin) steers it pretty clear of any obstacles. I'd suspect that it is a tired motor.
      Sounds like a dead actuator. It will work slow for a little while and eventually lock up. And if it's extreme, you won't even be able to lock it manually.
        is there a reason that it would be slow to lock, but just as quick to unlock?
          I have this exact same problem on the exact same door.
          Also, when I tried to remove a junkyard lock motor, I couldn't get the actuating rod to disengage from the locking mechanism. What am I doing wrong?
            i pushed down the pin manually on my rear drivers door and now its stuck. i have to pull the door panel as well..
            1988 MGM GS - Preferred Equipment Package 172A; InstaClear
            1994 MGM GS Montigua
            2002 Mustang GT Coupe
              The end has two 90 degree bends in it, you have to finagle it out just so or it wont co-operate.
                drill out the rivet holding the bracket... pull the motor and lift to perpendicular with the latch mechanism. It should slide right out if you keep pulling a little as you move it up.
                  I think one can get by without drilling out the rivet in the bracket. The actuator, to the best of my knowledge, pops into the bracket. So if replacing with an equivalent there is no need for relocating brackets.
                    Ok. So I'm just being a bonehead.
                    Any recommendations for replacement actuators? I have seen stories on here of people getting actuators and having them be junk really quickly. This seems to have happened while my dad was driving my car too; he had the tailgate one replaced twice and it quit within a few weeks both times.
                      I like OEM Ford. Unfortunately the correct type are increasingly difficult to find for sane prices. I'd like to try retrofitting later model lock motors, but I haven't gotten around to it. I think 87gtVic has a set of later model lock motors installed.
                        word. I have some pictures hiding around here someplace. I hope I didnt delete them.
                        EDIT: Found the thread...it is in the trash though so you guys cant see it so here are some pics
                          What did you have to do to retrofit the new ones? Anything special?
                            May have changed out the rod...but I had to drill a new whole for the bracket. It was so long ago......
                              The cheapo replacements dont last... I replaced my drivers door one and shortly after it died again. I just take em out and toss em. No more power locks.
