The other day while driving at night the drivers side window stopped working and I think I smelled burning plastic. I tried to get under the switch but I'm not sure how to get the power lock part off. What should I do?
Window stopped working, burning smell?
Open the door to make the courtsey lights go on. Trigger the suspect window motor and look to see if the lights dim. If they dim but no movement occurs from the window your motor destroyed the bushings inside the window motor. Just pull the rod connected to the power door lock slider straight down to remove it.~David~
Power lock rod? What's that have to do with fixing the window motor? Ooooh, you mean on the armrest.Yeah, that's sometimes got to be pried downward with something - but carefully, because the slider posts can tend to be brittle.
FWIW, deepsleep, there's been talk of the window motors being available new, and they're really pretty easy to install. But when I had this happen, it was a cooked window switch. Very easy to repair, just got to be careful not to break all that plastic.Last edited by 1987cp; 11-05-2010, 07:10 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Your motor is jammed most likely so I would say yes to bushings being gone. They like to break up and cause havoc.
Just to make sure, its only one click, its not like the rear windows. The rear windows go down about an inch, stops, and it makes a click click click sound. The front does just one "engaging" sound click...
All I have now is the passenger side window working so I guess I should just order bushings and gears for three windows?88 MGM 5.0 stock
