Hey guys, my car randomly died on me last night, and seemed to lose all functions controlled by the ignition switch. All of this occured shortly after I finished doing the rear brakes, but I can't see how they would be related, other than through the brake light switch. The symptoms are as follows:
-"Acc", "On", and "Start" Functions do absolutely nothing, no accessories work such as radio, power windows, etc.
-Radio cut out 2-3 times shortly before everything shut off
-Brake lights to not work
-Hazard flashers do not work
-Parking lights, headlights, and interior lights DO work
-Slight electrical burning smell from both interior and under the hood
I flipped through the owners manual while waiting for the tow truck, and found that there is an 18ga fuseable link that controls the brake lights and ignition switch, which is located near the starter relay. I'm assuming this is what blew since the brake lights work independently of the ignition switch on these cars.
What I need to know however is:
1. Where is the starter relay? I found the solenoid, but no 18ga fuse near it
2. What could cause this to blow? Bad ignition switch?
Any advice is greatly appreciated, I need this car back on the road ASAP. Thank you guys.
