I've got a vacuum leak SOMEWHERE and am gonna have to track it down.
While I'm in the process, I thought I'd go ahead and replace some of the components to the system, just to be on the safe side regarding possible future leaks.
I have to admit I know NOTHING about vacuum systems except what I've read on this forum.
So here are my questions:
I've read that the vacuum can on my left inner fender-well can be replaced with a newer, plastic canister from a later car, but what to look for in a replacement?
Any particular size of canister or model of source car to look for? Mine has the one outlet nipple that the tubing runs off of, so I assume I want another with a single nipple, right? Does canister size matter?
Also, I've read several metions of a "Tree" in the system....I assume this is a coupling of some sort for several vacuum lines to meet at, but where is it located on my car and where do I go to get a quality, new replacement?
Finally, do you just go to your local auto parts store and ask for vacuum tubing? Is it pre-cut to match the car's existing routing to the various components or do you need to do this yourself?....If so, are there any tricks to doing it correctly?
It'd be a huge help if there was some sort of vacuum system diagram that I could reference...Any suggestions there?
I know, TONS of questions from the noob, but it's hotter than satan's play-pen up here and I'd really like to get my A/C up and going!
ANY help will be greatly appreciated!
-Jon
-Jon
