'83 Marquis problems
    Hey,
    My cousins 1983 Grand Marquis is starting to act really goofy. Im going to try to explain it the best I can, so bare with me, hes in kansas right now, so I cant personally look at his car.
    But he loaned his car to a friend and the battery went dead on him, the guy hooked up jumper cables from another car and left them on for a while, came back out to check on it, and relized he had the cables on backwards. Now when you turn the key on, the fuel pump doesnt run, but if you put battery cables on backwards, the fuel pump runs in reverse, and all fusible links seem to be good he says.
    So what could it be??? Im thinking it might be the computer, but im not positive.
    Any help is appreciated, thanks.
    ---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
    ---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My Toy
    I know this sounds weird, but bear with me my friends aunt (i think) did the same thing to her 80's Impala. We swapped batteries and it worked fine, when i hooked it up to a battery charger, i came to the conclusion that the polarities got reversed (pos is neg/ neg is pos). I looked it up and it seems like it could happen.
    Just and Idea.
    George
    1986 Mercury Grand Marquis "5.0" (160,000)
    2011 Ford Crown Victoria "4.6" (54,000)
    2015 Jeep Wrangler JK Willys "3.6" (48,000)
      Bad solenoid?
      '79 Continental Town Car
      '90 Crown Victoria LTD
      '94 Crown Victoria
        Just and Idea.
        George
        That is pretty weird, but I just called him and he did use a different battery. So that cant be it. :/
        Originally posted by 79lincolnlover View Post
        Bad solenoid?
        He says everything works fine like it should, the car turns over and everything, so it cant be the solenoid, I dont think. But its just the fuel pump doesnt work, but yet it works (in reverse?) when the battery cables are put on backwards. :confused:
        Thanks for the responses though.
          Well it was an idea! haha
          What about the fuel pump relay?
          I know i went through a clusterf*ck when i managed to short out the relay on my car by getting it wet. (Dont pressure wash an engine btw)
          I had the same symptoms (minus the backwards thing) but maybe this would work?
          Just thinking out loud,
          George
            its not the relay i just put a new one in it and nothing
            1979 lincoln versailis, ford test ordered car, factory floor shift with bucket seats.
            1983 lincoln mark VI, all factory
            2015 Mustang GT 50yrs SHERROD, 6 speed 302, track pack, premium package, Custom JL sound system.
              Is it possible that the car was hooked up backwards for so long that it ruined the fuel pump itself? Mabye?
                maybe, im thinking about going and buying a new one but i dont want to spend the $ if i dont have to
                  ok so my cars not getting spark too, so unless there's a fuse going to the comp im pretty sure that my comp is junk
                    there is a fuse going to the computer... could just be a fuse-link though. Can't remember at the moment.
                      i wonder if hooking the battery up backwards could smoke the ECM relay. Probably should check all the fuse links though. I'm about 90% sure the ECM powers off a fuse link, though I don't know EEC 3 very well at all.
