What gauge should I run for this....? It is a Sun Super tach (if that matters) I just need to know what type of wire to go pick up. Im going to take apart the tach now and make sure all is alright on the iside, I would like to run the wire for it today while I wait for that damn ATC sensor.
Tachometer wire...
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Tachometer wire...
1985 GMC 1500
Not sure about the gauge wire to be used... but I was told you connect the signal wire from the tach to the green wire on the coil plug.'97 Cadillac Catera - 3.0 DOHC V6, 75k
Soon... Any '95+ Panther!
CLICK ME! Parts For Sale, SUPER CHEAP!!!
Originally posted by BGoins12 View PostNot sure about the gauge wire to be used... but I was told you connect the signal wire from the tach to the green wire on the coil plug.
I think your tach should have 4 wires like the newer ones do, unless they combined two of them that both need 12vsigpic
You should be fine with anything around 16 gauge.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
Alright... thanks. It is a 4 wire setup... one unlabeled black wire then 3 others labeled *Ground *signal *ignition Switch.
Ill get some color coded 16g as the other three are just blue... Im replacing it all because it is old shit, and there is only about 3 inches left on the tach.
Thanks again guys."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Gauge isn't real important, 16 should be fine. It carries no appreciable amount of current.86 Lincoln Town Car (Galactica).
Originally posted by 91grandmarquis View PostAlright... thanks. It is a 4 wire setup... one unlabeled black wire then 3 others labeled *Ground *signal *ignition Switch.
Thanks again guys.Originally posted by gadget73There is nothing more permanent than a temporary fix.
- Oct 2009
- 2878
- Keene NH
- Send PM
I opted out of putting the tach in... There is no place on this dash that it doesn't look like dog shit. Ill just keep it for later."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 99grandmarquis View Postit might be cool to take out the clock and get a small tach, then get some black plastic the cut a hole for the tach to fit in. i think it would look kinda sharp
TOTCG once just electrical-taped a 3-3/8" tach pod onto his steering column. After I bought the car, I moved it down where he'd had the AutoGage 3-gauge pod, which in turn is where the factory ashtray used to be.2012 Mazda5 Touring | Finally working on the LTD again!
- Oct 2009
- 2878
- Keene NH
- Send PM
It would... but I need the clock for my DD even if it is only in the summer. Im sure something will come to me."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
