ok my passenger side window has a problem. it will go up most of the way but when it get to maybe a 1/2 inch left it gets stuck tried shaking the window and making it go up and down nothing. whats the problem. I recently installed a new window weatherstripping on it as the original cracked on me and fell apart.
Passenger Window Problem
1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.Tags: None
did you lube it at all? can you pull up on the window? sounds like it may be time to rebuild the window motor, possibly1996 Mercury Grand Marquis - duals, PI cams, PI intake, J-Mod, MZT, BOC tune, 3.55s, 18in wheels
no i cant pull up on the window. i silicone sprayed the weatherstripping
Remove the window motor and inspect the plastic bushings. If they're shredded it can do weird stuff.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 91waggin View PostRemove the window motor and inspect the plastic bushings. If they're shredded it can do weird stuff.~David~
well i just fiddled around with it more i took off the weatherstripping and the window went up fine. so i re-put the weatherstripping on again and the window went up fine again. so i guess the weatherstripping wasn't on right causing it to not go up right.
