Alright guys I am done... I will post as much as I can, but I have to leave in 15 minutes for a bit so the rest will come after that......
Ok so I will start where I left off, with the new sockets. I ordered my sockets in the link above. They are different in the fact that they use a round base bulb and not a wedge base... HOWEVER this is fine as they lock in the same way as the factory ones, so the dremel work is fine and can be used. You will want some #2057 double filament bulbs for these.
Ok now I am going to post pics of the finished wiring, and then explain step by step what you must do to get it like that, so don't freak out when you see the wiring all spliced in.. ok?
Here is a picture of each side....
Drivers side all wired-
![](http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs056.snc4/35147_1486467318361_1134260087_1427519_3097000_n.jpg)
Passenger side all wired-
![](http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs056.snc4/35147_1486467278360_1134260087_1427518_4738476_n.jpg)
I apologize for my sub woofer being in the way... but you can still see the wires.
Step one is to remove the inner sockets on each tail light. (remember these are the innermost under the red lense, don't cut the innermost as these are the reverse lights and are under a clear lense. You technically want the second socket (only gray one) from the license plate.
This The gray guy in this photo...
![](http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs021.snc4/33431_1480682933755_1134260087_1413737_5493324_n.jpg)
Alright... snip snip with the brown and black wire on these. Now it is time to crimp in the new sockets. Just use crimps for 14-18 gauge wire, the kit comes with wire nuts, but I hate those as they are messy. Yes you can solder and heat shrink, and that would be the best way, but the crimps work fine.
to be continued....
to be continued....
