I was going through some of my notes and found this and figured I would post it up to help anyone.
One touch up down decode
-I don't know if it was decoded as thoroughly as I plan to do in this thread so here is the fool proof way to mesh two modules together to get that cool one touch up and down window!
- There are 5 pins on each module
- Pins read 5-1, left to right all while looking at the face of the module
- Number each module; 1 and 2 respectively so you can remember which one is which easily
- Pin 5 of module 1 connects to pin 5 of module 2 and then needs to me grounded
- Pin 4 of module 1 connects to pin 2 of module 2 and gets power from from one leg of the switch. NOT TAPPED but direct from switch
- Pin 3 of module 1 connects to pin 3 of module 2 and gets keyed power
- Pin 2 of module 1 gets power from the other leg of the switch. NOT TAPPED but direct from the other leg of the switch.
- Pin 1 of module 1 connects to pin 4 of module 2 and goes to one leg of the motor
- Pin 1 of module 2 goes direct to the other leg of the motor
