a/c pressure
    a/c pressure
    in normal operating cond. what should the high/low pressure read on my guages. thanks.
    Depends on outside temperature. . What year car do you have, and what refrigerant are you using? The factory service manuals have pressure to temperature charts, but its different depending what AC system you have and what refrigerant you're using. I can give you R12 pressure charts but that may not help you.
      89 g/m auto.climate control. system never was opened. it might be a little low now. r-12
        You're refilling with R12 then?
        Scan from the 86 manual, but it should be the same for 89 as long as its R12 yet.
          thanks.answers my ??????????
