Here's a question for the electrical gurus. I will be installing a second dome/map lamp in the rear of my car while I recover the coach roof interior trim and have the back glass tinted. I will be making up a harness to be snaked under the headliner to the original lamp for the power and grounds for the dome lamp (circuit 53 EVTM) and the map lights (circuit 54). I am also going to install a switch in the rear passenger area to turn on the rear dome lamp only. I know I need to put a diode in the harness in circuit 53 between the new and original lamps, very much like is illustrated on page 72 of the EVTM for the wagon cargo light, to keep the power from back feeding to the other courtesy lights.
My question is, what "size" diode do I need. A part number /source would be very helpful. Is there an easy way to determine which way the diode needs to be installed?
In case you are wondering why I am using the extra switch when the map lights can be turned on separately? Because I WANT to :lol:
Thanks for any and all help!
