Couple of Problems and Questions
    Well i went out to my car to inspect all the vacuum lines and found some funky shit that i need your help on.
    First Problem: what the hell is this plug for that i am holding in this pic.
    Second Problem: I found this vacuum line that broke off somewhere that someone put a screw in to the end of it. The line was located behind the CFI unit. Where does it go to.(See Pic Below)
    Third Problem: Doesn't a hose go onto the end of this spout and were to?(See Pic Below)
    Fourth Problem: What hose goes onto the end of this spout and where does it go.(Was located behind the CFI Unit).(See Pics Below).
    Fifth Problem: What hose goes on the end of this spout it is part of the cruise control which doesn't work and where does it connect to.(See Pic Below)
    Six Problem: Where does this Exhaust plate go it just rattles under my manifold.(See Pic Below)
    #1 that's the self test connector........it's useless the eec3 code list is 10 codes
    #2 that's the vacuum line for the egr valve
    #3 that's the baro/map sensor vent......btw we have one of those we harvested yesterday if you ever need it......350 bucks for a new one from ford.
    #4 see answer #2
    #5 yes it should have vacuum.....that's the high idle kicker for the ac......not sure where the vac source comes from tho
    #6 tear it off.......it's falling off anyway......if it's in the trash there is less chance of it rattling
      so were do i run these hoses to. Maybe this will fix some of my hesitating problems. And what does the EGR valve look like.
        Picture #4 is the EGR valve. Picture #2 is the hose for the EGR valve. Put those together and you're good.
        #5 should come from one of those solenoids on the driver's side valve cover. Look for broken plastic tubes in the area.
        #3 gets no vacuum connection. There are two tits on that sensor, one has a vacuum line, the other does not. If its anything other than that, its wrong.
          looks like one is broken on the bottom were can i buy a new one. also what will that do when i do connect it.
