OOOOOOOOOOOOK IM BACK AGAIN! LOL
SOOOOOoOoOoOooooo here is my problem... in detail
ok its night time. i start my car, twist the auto head lights timer toggle. my head lights come on. i turn on my blinker 2 pull out of my drive way...
huuuuum blinkers arent blinking...
i turn on my 4ways THEY WORK..
CONFUSED!... turn them off
i get out of the car...
MY TAIL LIGHTS ARE OUT AS WELL!
NOW WDF!
i go turn my 4 ways on again. they work in the back but no constant break lights...
in fact with 4 ways off and some one stepping on my break no break lights at all....
do i have a short?
or is this a fuse box problem?
the only light that i found bad so far is my front right marker light. about 2 go check my break light bulbs....
but a answer or maybe ideas soon would b a help i got work tonight.
and the cops as-s banged me last night, even tho i had my 4 ways on so i could get 2 work, i got a notice t5hat i have 5 days 2 get them working or i need a new inspection even tho i got 1, 4 weeks ago...
OK SECOND PROBLEM...
WHERE IS MY FUSE BOX.
my thoughts where under the driver side dash... couldn't find it. huuuum under hood? COULDN'T FIND IT.... am i blind?
1985 FORD CROWN VIC LTD 302CID
i will repost in electrical, which im looking threw now for like wise problems so i may just find my answer...
OK.... SO... FOUND THE FUSE BOX!
NOW.
THE ONLY FUSE BLOWN, IS A 20AMP FUSE THAT IN MY MANUAL SAYS ITS FOR MY CIGARETTE LIGHTS... EVEN WITH THE FUSE OUT 1 OF MY CIG LIGHTERS STILL WORK... MY REAR PASSENGER.
but i also checked my break bulbs. 1 of the bulbs 2 on each break light is out... (the 1's closer 2 the trunk lid) they have a tiny bit of black-ness on them. as soon is i touched them 2 un-tightened them n take then out. the bulbs broke lose from there bottom connectors, which stayed in the break light socket.
i got them out but. i mean wow they just crumpled like dust. so ill get some new bulbs aspa see if this helps but idk im quite aggravated with the hole thing.
my hazards work but my blinkers don't blink. and my break lights r still out and don't even light up when i step on the breaks
so idk ne help guys?
NOW WDF!
do i have a short?
NOW.
