View Post
fuse/load ?
gadget is this functionally similar to the trunk switch you described?
I am not particularly sure of the Mk VII switches but that one you have pictures is quite nice. It ground through the screw you would use to hold it in place and the other wire is connected to constant power. Mercury tilts and you get the light to turn on.~David~
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Been a while since I read this, Those LED strips Ive been thinking about for under seat and under dash applications, if they are out of sight they look really good and apply even light."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
so you're just running the circuit you'd create through the already grounded switch? neato. I'm gonna order a couple of 'em. I wonder how long one would last under the hood?sigpic
Originally posted by 1990LTD View Postgadget is this functionally similar to the trunk switch you described?
http://cgi.ebay.ca/Mobilistics-Mercu...item2c53db410086 Lincoln Town Car (Galactica).
Holy crap I didnt even read the description of that thing you linked to. That one sends a ground out through the wire when the mercury is triggered. That has no light with it at all and is worthless unless you link it up with an alarm etc.~David~
I'm not looking for something with a light in it, though. I want something to complete the circuit and trigger my light strips when the trunk opens.Last edited by 1990LTD; 04-27-2010, 07:46 PM.sigpic
That would work then. I still say tapping into the existing wiring will be the easiest way.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
If it's LED just tap into the current wiring, that is how I would do it. Again electrical is not my strong point."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 87gtVIC View PostThat would work then. I still say tapping into the existing wiring will be the easiest way.
I did, that's why I need the switch. The light socket in my trunk has a tilt switch built in with constant 12v going to it, so anything else I hook up to it also has constant powersigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
what about rigging up a door switch? Just an idear... Seems like that could work if it were placed in the gully were there is no carpet between outside of car and trunk. again I really don't know shit about electrical. It is a miracle the 3 guitars I re wired don't kill me."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
door switch would be harder to do. You'd have to make it hit the hinge or something. The tilt switch just needs a mounting screw, and it makes connection when you open the trunk. Theres probably a suitable factory hole that it could be mounted to. The switch won't handle much current, but LEDs don't draw much. If its a concern, have it operate a relay and put your load on that. The Mark VII runs 2 or 3 164 lamps from it's tilt switch.86 Lincoln Town Car (Galactica).
I might relay it just for the hell of it, I have no idea what else I might want in there in future.
There are two holes that the current tilt light clips into, should be fine there. I won't need that switch anymore so I'll take 12v from there, I just gotta figure out what to use to adhere the light strips to the car. Thanks for the help gents.
Think it would handle a couple of led strips?sigpic
Originally posted by 1990LTD View PostI did, that's why I need the switch. The light socket in my trunk has a tilt switch built in with constant 12v going to it, so anything else I hook up to it also has constant power~David~
