My steering column gets hot on top when low beams are on and I think I smell the plastic shroud heating up. I think the headlight circuit runs through the turn signal, high beam, hazard light unit which I know has the bundle of wires running across the top of the column. That means these wires are getting hot. My question is whether or not there is anything in particular that might have gone bad that can be replaced to reduce the load on this bundle of wires?
I know there is the headlight switch but that is hard to get to. I took one off at PicknPull once before and it was easier for some reason because it was a GS model. Then I looked at my LS and was like, what about all these wires and brackets in the way? I also recently cut the bundle of wires off one in the yard just in case I need that.
Let me guess, the problem is not something simple because that would be my luck since I don't pay people to do stuff I can do anymore but I don't have a place to work on my car without getting a nasty letter from the rental office about the provisions of the lease or having the police pull up and say the neighbors are going to complain if they notice things get too disassembled (like a steering column laying on my seat just to see under the shroud). By the way, nothing is not working yet regarding the turn signal, high beam, hazard light unit. I guess I should convince my brother to go in with me on renting a storage unit big enough to work on cars, eh?
