Ok, so I remember reading somewhere on here that you could easily convert to manual temperature control if you got the cable from a non ATC car. So as of now I have the dash down in my 89 GM w/ ATC and I found out something interesting. I don't know if anyone else knows this, but I took the cable that connects from behind the slide lever on the temp controls on the dash that runs up and connects to the ATC sensor, then I removed the blend door vacuum motor and stretched the cable over to the blend door lever and it reaches! So now all I would need to do is punch the box with a screw or fab up some kind of bracket and I'll have manual temperature control. Yay! Pics.
Heater evaporator blend door vacuum motor. Here you can see the black antenna cable.
ATC sensor and cable.
Blend door lever.
ATC sensor cable removed.
From here you can pull the cable from over the vent tubes and under the dash and route it the the blend door lever.
Here are two of the white blend doors. I believe these are for the floor and the defrost vents. idk. I manage to break one by accident and the other was already broken.
And here's the back of the dash with the vents removed.
And here's what I believe to be the plenum area and 3 vacuum motors for the doors.
So in addition to everything I just posted I have questions, if I were to bypass the ATC what would I need to do? Because if I just left it hanging wouldn't that create vacuum leaks?
Blend door lever.
