courtesy light power?
    Where can I steal 12v from the courtesy lights other than from inside the doors/headliner? At the fuse box wouldn't work. I need it to come on with the courtesies.
    do you have under dash lighting? If so then just steal it from those lights.
      That's what I'm trying to rig up
        damn. Well then just steal it coming out from the door switches. Should be accessible somewhere along the line underneath the dash.
          I forgot about those hateful things, thanks haha
            you sure the one plug harness is not just sitting around under the dash anywhere? The way the think worked was by the bracket to the courtesy lights was constantly grounded, and then when the door switches were released power was distributed to the lights.
              You should have something dangling down there...
