The automatic parking brake release thread
    Originally posted by slymer View Post
    "As seen on TV"
    Metwrinch
    http://www.metrinch.tv/
    Love those. Have a wrench set too. One of the best things ever.
      Ah yes, those. Expensive stuff that. Big investment just to have fewer tools to lose, but I could see times when it'd be worth it.
        Mine was a gift. I guess they are fairly expensive, now that I look at them.
          mine has lasted almost 10 years so far. I've also used the u-joint with a breakover bar and didn't destroy it... it just bent ever so slightly and is now a little sloppy. I've used the sockets numerous times with impact tools with no problems too. The ratchet sucks, but I have yet to destroy it. This is also the toolbox I keep in my trunk for working on crap when it happens on the road. I did add another 6" extension to it (resting between the 2 rows of 3/8 drive sockets) which allowed me to plug the heater core lines when the original flush T that had been installed, some eon before I bought the car, busted. clamped the open hose ends to the 2 extensions and rolled over to the parts store and got a new flush kit (so I'd have the adapters to work with the T) and replaced that in the parking lot. I lost only about a cup of coolant so I just patched it back up and went home. topped off the side tank and left it. I typically use that kit to help others with their cars though. It has seen a LOT of use.
            my car hisses from the general steering column/under dash area when i change directional gears.
            i am fine with plugging the vac line going to this thing if that's the culprit, however, my automatic parking brake release seems to work fine. what do you guys think?
              It's probably just leaking a little, for now. I'd try to fix it or at least plug its source off. Good luck, in 90-91 cars the equivalent part is high up on the column, up behind the dash. You might get to it with the knee bolster out, I haven't tried (it's functional in the 91 )
                I gotta get the knee bolster out anyway for some routine maintenance, bulbs and shit
                  any idea where the source of the vacuum is? i mean, manifold vacuum, but any idea where the hose for the parking release is coming from?
                    It works the same as the older setup, you can see where the line comes through the firewall and follow it up to the switch.
                      awesome. i've got a busy weekend
                        does anyone want pics of the setup on my 90? might be good to have for reference purposes
                          just bought a new one for $40 picking it up tomorrow.
                            New? As in, new?
                              yep brand new and put it on and still have a leak so its not the switch its something else. any ideas. will not disengage the parking brake. i love this feature and want to fix it.
                                Dealer part, or did you find one aftermarket. If its aftermarket, where did you get it?
