The automatic parking brake release thread
    it's a Standard Product. got it from Ceekay's One in a million auto parts. it's what match the original part number on the old one they just pulled it up with the old ones part number.
      Are these still available from the dealer?
      Nick
      88 Colony Park LS
        no. i dont believe so the dealer is lousy in ordering parts for old cars plus more money. the part is made in the usa.
          PN, please.
          Is this the Cee-Kay's you are referring to? http://www.merchantcircle.com/busine...c.570-288-7278
            yes thats it and the part number is
            OEM is E45C-2B623-AA
            Standards switch part number is DS454
            heres a link of the product. listed on rockauto for $34.
              Mine hisses slightly when I switch from reverse to drive as well. Always has, and as soon as you get it in gear it quits. I think it's the vacuum motor engaging to release the brake, because it sure doesn't sound like a leak to me.
                yea the one in my 92 is quite noisy too.
                  what else could cause it not to operate the switch is new what else should i replace that could be the cause.
                    the system is pretty basic. You have a vacuum line that runs from the tree to the valve, then from the valve to the vacuum motor. If the vacuum lines or the vacuum motor is bad, it won't release. I also want to say there is a bit of wiggle room where that valve mounts, so if its not adjusted properly it won't operate. There also ought to be a tang or something that it engages on the shift lever shaft to move the valve internals. if thats not set in the valve where it belongs, it won't work.
                      pic of the vacuum motor please and how to take off.
                        ok i have a new problem the parking brake releases fine. But i cant apply my Parking brake in park without having the car shut off. I pulled the hose from the servo and there is air suction all the time while the car is running, whats the problem.
                          check for shorts from the e-brake assembly against the ditch light harness. my 88 liked to blow the fuses to hell before I found that when my e-brake was on. if it shorts just right, it may kill all kinds of crap.
                            the parking brake release is bad and passing vacuum constantly. Either that, or its not installed properly and not moving the slidey bit back to the park position.
                              bah... I read that first post totally wrong. It's that little horseshoe shaped thing (part that gadget is talking about) near the firewall. somehow it's either come free from the shifter shaft, not installed properly as stated, or the brake release is plumbed directly to the vacuum source. There should be no vacuum passed from Park to Neutral. It should only apply vacuum to the brake release in Drive settings.
                                have to see if it came off. BRB
