My check engine light came on yesterday. How do I diagnose it? It's a 2003 GM. Also, my radio has been intermitantly not working.....it gave me problems last year when I bought the car...worked almost all summer, now this past week is not working again. Does not come on at all...suggestions?
check engine light
- Oct 2009
- 2878
- Keene NH
- Send PM
Radio may be as simple as a loose connection behind it, is it factory or aftermarket? usually its a ground issue if it keeps coming on or off, sometimes it can be power too. To read the check engine light you can pick up a code reader at an auto store with a book that tells you what the code means. Thats the easy way, they run about 100 or so bucks but are a handy tool to have."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Drop by Autozone or some other auto parts place. They can read the codes for free.86 Lincoln Town Car (Galactica).
thermostat
Thanks guys...I went to Autozone and they chekd the code. said it was a thermostat. The guy said it could also be a temp sensor, or an air pocket in the cooling system. So I changed the thermostat and the check engine light was still on. So I went and had the system flushed. I asked the manager if they noticed anything strange when they flushed it and then I told her about the check engine light. She checked the engine code again and I notced the light was off when she stared the car. She said the check engine light had to be reset. Never ehard of that, I would have thought it would have reset itself. but anyways, problem solved!
Now I gotta look into that radio......
