Need help locating fuel pump relay
    can someone please help me locate the fuel pump relay on my 1985 towncar(cfi)
    sigpic85 towncar stock for now 1 issue
    Should be on the driver's side inner fender. I believe the CFI cars have both the ECM and fuel pump relay lumped together kind of near the master cylinder. It should be under a plastic cover, and there are 2 relays in there. One is fuel, the other is ECM. I think the green one is the fuel pump relay.
    also moved to a more betterer forum
      thanks
