HId headlights
    I am using two relays because your way does not make sense to me.
    Hi 87gtVIC
    Oops yeah it doesn't make sense to me either you would need a switched supply to the relay pin 30.
    Regards
    Dereck
    President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
      lol Relays sure can get one confused. Happened to me tons of times.
        here i thought you all would enjoy this
        sigpicTHE H.I.D MASTER
        87 mercury grand marquis
        88 crown vic lx
        89 mercury colony park ls (sold)
        89 mercury grand marquis (sold)
        00 ford crown vic lx hpp
        03 mercury marauder aka punisher (sold )
          looks great mang. I would like to do that but I don't wanna spend the money lol. for the very least make a relay harness so you don't burn your switch out.
            Found another nifty diagram....with a 5 pin relay this one uses a fuse :p
            this is the diagram I pretty much used. I made my relay harness I ended up using a stock harness from a 89 vic. I then just added the relay's it really does make a difference output wise. the only thing is it is pricey if you have to go out and but the parts you need lol
              i have my harness made out of parts i found in my house lol i like free upgrades.... A sneak peak of it
              Its really just a sneak peak
                i'm going to do the relays this winter along with the rear end, in my down season at work dont have alot of time right now to play with the car. its so bad right now a friend came over to use my tools , and in exchange he did my plug cap and rotor
                while i was at a funneral
                88 crown vic lx
