I just found this great diagram on doing the relay upgrade even though he labled the relay pins incorrect lol here is the correct layout:
85 ground
86 multi switch input
30 starter solenoid
87 headlights
It was for a 4 eyed fox body but it should be very similar i have not checked with my EVTM yet to see if they are in fact the same
This is using a 4 pin relay..i am just gonna use 5 pin relays because i have a whole stash of them
I also see some guys running circuit breakers between the battery/ solenoid and the relay. Is that required?
85 ground
30 starter solenoid
87 headlights
