What exactly is this switch thing called? just a multifunction or combination wiper switch?
Wiper switch
The 'brain' might be in the dash, but the switch is whats going bad.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostThe 'brain' might be in the dash, but the switch is whats going bad.
Just to clear things up. There is a wiper switch, and a turn signal switch for my car. I have someone telling me that it's the wiper switch, and another telling me that it's in the turn signal switch... What's going on then? I'm just paranoid, cause I donn't have the money to replace the wrong one.
1991 CV LTD LX Stock 5Xk
Originally posted by Morris View PostJust to clear things up. There is a wiper switch, and a turn signal switch for my car. I have someone telling me that it's the wiper switch, and another telling me that it's in the turn signal switch... What's going on then? I'm just paranoid, cause I donn't have the money to replace the wrong one.Originally posted by gadget73There is nothing more permanent than a temporary fix.
It may not be the switch or the module. My car does the same thing, where only high speed works continuously, and it doesn't always park the wipers when I shut them off. I've got completely new wiper switch, tried a second module, and the problem was exactly the same. The only time I got the issue to change at all was when I rebuild my wiper motor. It went away for a few weeks until it eventually came back. So that tells me the contacts are done inside the motor, and only when you apply the extra amperage of high speed is it able to reliably keep flowing current.
Woah, didn't even think of the contacts in the wiper motor going bad. I didn't want to think that it was the switch in the turn signal, because I couldn't get it to do anything different if I wiggled it around.
Yes the fan shroud and over flow out of a 90 TC is the desirable one. While you are at it grab the air box and intake tube as well so you can looks something like this:
My engine bay
It has the 90 TC shroud and coolant tank.~David~
Originally posted by 87gtVIC View PostYes the fan shroud and over flow out of a 90 TC is the desirable one. While you are at it grab the air box and intake tube as well so you can looks something like this:
My engine bay
i totally misread what your post said. 91 has a totally different engine, so not sure how much really interchanges.~David~
Lame. I had my hopes up for a second.
That looks nice though. I'm going to have to run down a 90 somewhere. I'll check with have24wheel to see if there's anything down south.
Originally posted by Morris View PostWoah, didn't even think of the contacts in the wiper motor going bad. I didn't want to think that it was the switch in the turn signal, because I couldn't get it to do anything different if I wiggled it around.Originally posted by gadget73There is nothing more permanent than a temporary fix.
I know that the air box will still bolt right onto your inner fender though. Not sure about the tube... But you didnt even ask about that...so I will just shut up~David~
