i was wondering if you could tap the fuse without using one of those fuse taps? ive been looking for them but i can't find them anywhere in canada
tapping the fuse
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Can't you order them online from someplace?
Originally posted by 1987cp View PostYou can get a doohickey specifically to do that? I never knew that. My horn is powered by a piece of wire with the end fanned out and folded over the end of a fuse.
Yea there are doohickey's made specifically for that purpose, but I have only seen them in the mini versions....
I am currently just wrapping wires around the the fused side of the fuse as well.~David~
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Radio Shack
Vetco Electronics
Amazon
You know, that Google search engine works really well. I'll bet it just might catch on...
same here I've done it. that what I'm doing for my volt meter
Originally posted by Nathan in MI View PostRadio Shack
Vetco Electronics
Amazon
And is there a button I am not familiar with to assist in making normal text double as a link?~David~
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
In the reply window, hit the little button that looks like a globe with two chain links in front of it. It'll pop up a little window that you can paste the URL into. Click OK, and it will make a link in your reply. Then, highlight the link and type whatever you want it to say.
Auto Zone
Adv. Auto
In the fuse section.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Originally posted by Nathan in MI View PostIn the reply window, hit the little button that looks like a globe with two chain links in front of it. It'll pop up a little window that you can paste the URL into. Click OK, and it will make a link in your reply. Then, highlight the link and type whatever you want it to say.
ohh thanks a million..i always resorted to manually typing in the formula to do that.
test
tappin the fuse
woot woot you the man!~David~
Originally posted by 87gtVIC View Postthose single metal strips are so cheap looking, you have the ideal "piggy back fuse" within the second link.
And is there a button I am not familiar with to assist in making normal text double as a link?Originally posted by gadget73There is nothing more permanent than a temporary fix.
I am sure they work great, actually a lot easier than shoving the wire in with the fuse I am sure.~David~
Yes, especially when you use one of these to tap, rather than an uninsulated one.
Funny thing is on my car there is not a lot of room between the cover of the fuse panel and the fuse panel itself, so only the wire shoving technique works well. You have it different on your 91.~David~
