Block heater?
    Block heater?
    I live in Norther ND, and there are times in the winter when block heater seems to almost be a necessity. I noticed that there is no plug in on my car, so I'l like to install one. What should I go with?
    1991 CV LTD LX Stock 5Xk
    I am curious as well. Winter up here is rough.
      dunno about the stock block heater, but I found this with a quick google search.
        Ask Monterey1962. He also lives in ND, and I know he's got a block heater in his car.
          Get one that plumbs into the heater hoses...
          2000 Grand Marquis LS
          Mercury Owners Group member
            Not sure how effective that would be if the coolant doesn't circulate. Most of the ones I've seen either go into the dipstick tube, or the better ones replace a freeze plug.
              The unit has a pump that circulates the warmed water...
              Those freeze plug ones just heat up a small area of the motor unless you put one on both sides.
                Found it...
                  That is what I want.
                  Now, how the hell does it work?
                    Should just have a little pump and a heating element that heats the coolant and shoves it through the sysem. Ray made a comment in another thread about this sort of thing normally plunbing into a radiator hose; my question is whether it could go into a heater hose.
                      From what I remember it it routes from a heater hose to the lower radiator hose some how. The one I have does not have directions.
                      It's for sale if anyone wants it, I have no use for it.
                        It looks, from the parts there, that it would have to go into the heater hose somewhere, cause the radiator hose would be way to big for it. I can't think of anywhere to plumb that in.
                          One end routes to a heater hose. The other routes to the lower radiator hose. The part that plumbs into the lower hose is not included with the kit and has to be purchased separately.
                            Ah. I think I'll go in through the freeze plug. Cheap & eazy.
                              I think it just goes in the heater hose.
                              The freeze plug type will keep the whole motor warm, it is the same type used in the big trucks. Plug it in overnight and the motor will think it's June.
