Gas Gauge Reads half when tank is full
    Hi guys, me again, with another problem. It seems Vicky has developed another problem with her. I filled her tank today, and the damn gauge only went up to half a tank. So the only thing I can think of is the sending unit in the tank has crapped the bed. Do I have to drop the tank to service the sending unit? And where would be the best place to get one?
    :bump:!!!!!!
      I got my sending unit from teamfordparts.com and to install it you do NOT need to drop the tank, matter of fact, it only takes like 15 minutes.
      -2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
      -1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
        Ok cool, but it's safe to assume that it can't be worked on with the tank full. What's a good point that I can work on it without taking a bath?
          You want the tank less than 1/2 full, the emptier the better. The access plate is on the front of the tank, just above the rear. Have a look in there and you'll get a better idea of how far down the fuel level needs to be.
          Could also be a bad float.
            How do I remove the float from the rest?
              Should become obvious once you have it out of the car. Probably a clip, but I don't remember.
