Right Flasher Not Blinking
    My right flasher isn't blinking...any idea what's wrong. I changed the bulbs.
    New 87 LTD Crown Vic
    Only the right side, eh? That'd rule out the flasher, so it could be either wiring or the switch.
    Do the four-ways flash correctly? If so, that should rule out a bad ground.
      The actual signal outside or the indicator light inside?
        make sure you've checked ALL the lights. there are two in the tail light housing. I thought I'd checked them all, but someone (1987CP?) told me to double check, and sure enough one was dead in the tail housing even though it wasn't obviously out.
          That is true, I'd forgotten about that discussion. :p
            wat switch...and the indicator on the inside doesn't blink either
              That would be the multifunction switch on the left side of the steering column that sort of controls the turn signals ....
              I readily believe that your indicator isn't blinking, but is it coming on at all? For example, the typical "bulb out" behavior where the indicator comes on steady when you pull the stalk up?
              Still waiting for an answer about whether the hazard flashers work ....
