hello everyone, im new to the forum but have been reading this site for well over a year now. Have one quick question for the 3g upgrade. will an alternator for a 95-96 mustang be a direct fit into the 89 crown victoria brackets? If not which 3g alternator will be a direct fit ?
? about 3g alternator
welcome to gmn!
these are the most commonly used 3ag's that will fit in the stock bracetry for the small frame alternator.....if your 89 has/had the heated windshield option it will be the large frame 3ag
small frame 3ag
94-95 mustang 5.0
91- up taurus/sable 3.0 ohv
91-97 thunderbird/cougar 3.8
large frame 3ag
91-95 taurus/sable/continental 3.8
93-98 windstar 3.8
what Lincolnmania said...95 mustang is 5.0 96 is 4.6.....means no workey for you...but 94 will work.~David~
I got my 3G off a post 1996 mustang 3.8Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
If you have belt fitment issues, you can swap the slightly smaller stock pulley onto the 3g and get a little more clearance.86 Lincoln Town Car (Galactica).
Originally posted by 85crownHPP View PostI got my 3G off a post 1996 mustang 3.8~David~
Originally posted by gadget73 View PostIf you have belt fitment issues, you can swap the slightly smaller stock pulley onto the 3g and get a little more clearance.Last edited by PICKUP6772; 08-05-2009, 05:18 PM.
I ran stock belts with the larger 3g pulley without issues for quite some time. I honestly don't know why some people can make it fit and some can't, but all I can tell you is it worked for me, and that the slightly smaller pulley will give you a little extra room to work with on the belt. I wouldn't be too surprised if things changed very slightly year to year. I've had some cars that were a bitch to get the belt on, and some that you couldn't make it tight enough. Who knows.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI wouldn't be too surprised if things changed very slightly year to year. I've had some cars that were a bitch to get the belt on, and some that you couldn't make it tight enough. Who knows.
I want to say I've noticed slight variances in the case with different applications I've harvested/looked atPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by PICKUP6772 View PostUuuhhh, no you can't. Need belt #K060507. Look into my post: AND YET ANOTHER THREAD ABOUT 3G GOODNESS. If you check the other post about the conversion, you will see the other guys had the same thing with the pulleys.
n00b question: What do I look for in a used alternator? I mean, assuming I know it's coming off of the right vehicle, several of which I have to choose from, how can I tell if it's any good? Can I?sigpic
more n00bage; what does the 3g designate? 3rd gen?
could i get a 200 amp if i felt like it? i found a deal on one used but i might just ebay a new one for the sake of having a new one.sigpic
Originally posted by 1990LTD View Postmore n00bage; what does the 3g designate? 3rd gen?
I should have said I found a deal on a used 130A but if I'm gonna go new, I might as well go bigsigpic
why are you going to need more than 130 amps?
Look for one that looks like it was recently replaced of course, always give them a spin and check for pulley wobble and bearing noise.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View Postwhy are you going to need more than 130 amps?
Well, basically just because I cansigpic
