Cornering lamps flash with turn signals
    The cornering lamps, the white lights that illuminate out the bottom front side of the car when that side turn signal is actuated have started flashing along with the turn signal. I have replaced the turn signal relay in the fuse box (the big, round one). They used to stay illuminated steadily until the flasher went off, but now they flash with the flasher. Does anyone know what may cause this, I cannot find a relay or fuse for those lamps in particular. It's an 88 Lincoln Town Car. Thanks!
    cornering lamp relays?
      Hi ZacharyCrowe89
      I think you will find the cornering lamp relays uder the dash above the drivers feet, they look like two silver turn signal flasher cans.
      Regards
      Dereck
      President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
        I will take a look again for those, I just don't remember seeing any other can-type relays.
          Hi
          Regards
          Dereck
            What he said. The relays are probably tired, or your alternator is. Low voltage will make them do this, so you might want to check that out.
              Alternator is pretty new, and thank you for the diagram. I will take a look at this tonight.
                I had an alternator die at 2 weeks old once, so you never know. Wouldn't be a bad idea to double check things.
                  I agree with Thain, Vicky used to do that when I had the old alternator in there with a load on the charging system (rear defroster, blower motor, radio). Doesn't do it anymore.
