Loosing vent under engine load
    Hey guys, I have a slight problem with my Grand Marq. Under heavy engine load (i.e. going up a hill on the highway in OD), I loose enough vaccum that the climate control begins to from vent to defrost, sometimes completely. Does anyone know where I could start looking for leaks? I sprayed all of the lines under the hood with starting fluid to no avail, and plugged my leaking parking brake release.
    Car: 1988 Grand Marquis wagon
    - No ATC
    -Only happens under heavy engine load.
    Thanks for you input!
    -Nick
    Nick
    88 Colony Park LS
    What condition is your soup can in?
      Soup can is also my first suspect, but the one-way check valve at the firewall vacuum tree can also leak internally, and cause this.
      And don't spray starting fluid around. That shit is real explosive. If you had a leaky plug wire, it could have literally blown up in your face.
        I was worried about the plug wires and the warm exhaust, personally I didn't feel that comfortable doing it but all of the guys at the shop I went to said it was fine so...oops. Soup can has a bit of surface rot but when I hit it with the fluid the idle didn't change. The firewall vaccum tree is the little white thing with like 3 lines coming out of it located smack dab in the middle of the firewall?
        Nick
        88 Colony Park LS
          Ya that's the tree. Keep using the starting fluid and you won't have to worry about any vac leaks.
            Use a vacuum pump to check for leaks, or if you're confident in your manliness, just put the hose in your mouth and suck. If it leaks, you'll find it.
                The soup can plasticish line is bad, or the can itself is rotted out. Mine broke, and whenever I accelerated the controls would revert to defrost.
