Just discovered that the front right turn signal comes on when required but does not flash - neither on the dash or the signal itself - it just stays lit until I disengage the turn signal lever. I realize that both turn signals are controlled by one flasher pot, and as the left turn signal works normally, I assume that this can't be the issue - or can it? Any ideas? TIA.
Turn Signal Mystery
