The signal works but the flashing left arrow isn't making an appearance inside the car. Right one is fine. What do you think?
signal not flashing inside
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
bulb in the cluster burned out........the cluster takes 194 bulbs
So it's just a matter of getting inside the cluster and replacing the bulb?sigpic
Yea, well removing the cluster to access the bulb.~David~
Originally posted by 87gtVIC View PostYea, well removing the cluster to access the bulb.
Gotcha. Now I need to learn how to do thatsigpic
Haha yea. I never touched one so i cant help you there.~David~
90 and 91 are easy since there is no speedometer cable
remove the bezels and unscrew the cluster then you should have room to access the bulbs.....if not you have to squeeze the connectors and pull to get them off
How do I get the bezels off?sigpic
take the screws out!
Pop off the long skinny trim on the dash and you will see them. Gotta hit the release on the headlight switch to get its knob/bezel out so you can pull the dash panel off all the way. Got to take the drivers knee bolster out to reach up and hit the switch button iirc.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
It's the trim I was wondering about actually, it just pops off? thanks.sigpic
Are all of the bulbs 194s? Wondering about how easy it would be to interchange the existing speedo, fuel, temp etc with different colorssigpic
quite easy - been done
oh, the greenish filter on the 90-91 speedos is a film that isn't removable... blue color worked out well, other colors might look weird going through the filter.
Last edited by 85crownHPP; 06-17-2009, 06:25 PM.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
hah - I must have PM'd you at the same instant you posted that.sigpic
lol... reply sentPete ::::>>> resident LED addict and CFI defector LED bulb replacements
