I've done a bit of work to this beast. Most of it has been brakes and suspension. Now i have an entirely new breed of problem. This time, its electrical.
The factory stereo was making a lot of noise, and was just really unpleasant to listen to. So I bought a new stereo. We hooked it up, and it sounded mediocre. So I bought new speakers. After installing them, the radio sounded great. The only problem is, When i hit a bump, or i am going over 45 miles an hour, the radio tends to sound like a ground wire is losing contact with whatever its grounded to. (Lots of hissing and loud noises)
At first, I suspected this to be a fuse that had broken, but was still making weak contact, so I checked the fuse box. All the fuses look good. I don't have a wiring diagram because the original owner file 13'd the manual (...).
I also have a second electrical problem, The power windows will roll down (except the back two, but that's a motor problem for sure.) The only way to roll down the front two is from the master panel on the drivers side. I was wondering if anyone knew of a second fuse box on a 1987 Mercury Grand Marquis?
Thanks in advance, Nick.
