Hi My 88 CP Wagon just got back from the garage after a tune up. (TPS replaced,IAC replaced, PCV valve and breather filter replaced,minor vacuum leaks fixed,plugs and wires replaced.)
When I got back just now after a long drive and after stopping at the gas station a few miles back and filling the gas tank, my fuel gauge was suddenly showing empty, the fuel warning lamp came on, the power windows wouldnt work and the AC fan worked but the compresor wouldnt kick in.The headlights, interior lights, wipers and indicators are OK. No other warning lights came on, other than the fuel warning light. Car moves well and engine ticks over normally at idle. Cassete player is working normally.
After I waited a few minutes and restarted the car everything worked normally, and then the fuel gauge slid to empty again and the fuel warning lamp came on,. This happened a few times intermittently.
Where do I start the trouble shooting procedure? Could this be a blown fuse or link? And why is it intermittent?
Thanks
Gopi
Thanks
Gopi
