So I decided to swap my front turn signal bulbs from clear back to amber, but I notice my passenger side bulb is a lot less brighter then the driver side, thought it was due to the fact that i dropped the bulb before installing it, but after swapping it for a new one, the issue persists. Is there a problem with the socket? or a stripped wire somewhere?
Front turn signals question
Originally posted by PICKUP6772 View PostCheck for a bad ground. While you have the parking lights on, put on the hazards/4-ways, and watch them. If they alternate, then you have a bad ground on the passenger side. If they don't alternate, then check for a bad/corroded conection in the socket.
thanks
4thPanther..03 MGM LS
previous panthers: 87 MGM, 85 CV 2 DOOR, 89 MGM.
well i put the old bulbs back on and problem fixed, turns out the old bulbs were part #1157, and the sold me 2357, funny thing is advanceautoparts.com also shows 2357 as the correct bulb? is their database incorrect? what bulbs are you guys using for your front turn signals?
Originally posted by PICKUP6772 View PostI'm using 1157NA's. Yeah, that yellow stuff is an anti-corrosive. Messy as hell, but it works. BTW, that's my 89 in my avatar.
2357 is the updated replacement for an 1157. I have absolutely no idea whats so much better about them, or how they're updated considering light bulb technology hasn't really come far in the past 50 years or so.86 Lincoln Town Car (Galactica).
