Its stays on till I get on the gas than it turns off goes to heat(or vent blows hot air) and blows thru the defrosters. What is my prblem and how can i fix it?
Ok I got a problem with my air conditioning how can I fix it.
check the soup can
that can really have something do do with it? the vacuum playing games??~David~
yes
bastard soup cans..btw my ac was working wonders today.~David~
if its is the soup can what can I do, and I have looked at it before but I dont see any holes what am i exactly looking for? Should i use a vaccum gauge and where should i put the gauge?sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
check it for vacuum leaks. Also check the thermal blower lockout if you have one, and the check valve at the vacuum tree for leaks and to make sure it works. The system defaults to hot defrost (ATC) or defrost (non-ATC) in the event of a loss of vacuum. The soup can's purpose is vacuum reserve to hold the doors to your settings when accelerating. The check valve is part of that too. The TBL switch serves little purpose other than to leak, but if its sucking air it will empty the soup can real quick. I found this out on my car after replacing a defective soup can for $28 and still having it shift to defrost.86 Lincoln Town Car (Galactica).
I have seen some of you guys with a round ball type soup can. Where did you get it from? I have looked and all I can find is the same thing I have.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Chevys have the round ball. Later Panthers have the square box that looks computer-ish. There are also two sizes of soup can, the Dinty Moore size and the Juicy Juice sized can. ATC got the Juicy Juice can, non-ATC got Dinty Moore. Functionally, I don't think it matters at all, so long as the thing holds vacuum.86 Lincoln Town Car (Galactica).
The black plastic box on the driver's side fender with the yellow writing on it is the late panther vacuum box, and it also houses a few relays. 85crownhpp put this (in addition to numerous other upgrades) on his 85 because it doesn't rust like the soup cans and just looks a hell of a lot better. I don't think I've ever seen anyone put the round ball one on a box panther, but I could be wrong.Originally posted by gadget73There is nothing more permanent than a temporary fix.
does anyone make the coffee cans brand new? I was just thinking of tryin to make one out of a juicy juice can lolsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Functionally, I don't think it matters at all, so long as the thing holds vacuum.Chris - A 20th Century Man \m/ ^.^ \m/
Originally posted by 83countrysquire View Postdoes anyone make the coffee cans brand new? I was just thinking of tryin to make one out of a juicy juice can lol
I bought a brandy new can in 2006 or so, I think it cost me 28 bucks.86 Lincoln Town Car (Galactica).
