I had the car running earlier for maybe 2 minutes and the amp light came on. I left the house at 7 and came home at around 9. I left the battery connected while i was gone and went out around 1145 and absolutely no power at all and the battery was fully charged earlier. What would cause this? Im thinking a short somewhere. Any thoughts?
Amp light
mike you said the fuse link burned. check in the alt harness for a fuse link replace that and see what happens
Nothin burned that i know of. I hear a buzz noise from around the dash when i have stuff going. like lowering or raising the windows i get no power from the battery after charging 4 hours and the lights clock and radio shut off, then i get full power back. What would cause that?2018 F150 XLT 43k
1970 Buick GS 455 Stage 1 44k
1968 Buick Riviera
Bad battery connections, bad ignition switch. Check the cables at the battery first, they tend to get crusty, and the wire inside the jacket will turn green sometimes. Bend them around a bit, if they crunch its probably time for new. Ignition switch is a good idea to replace if yours is original. They're known to start fires and cause all sorts of problems when they get intermittant.86 Lincoln Town Car (Galactica).
You might not even need to spend any money! like suggested start with the connections... wire brush the battery and solenoid posts, including the insides of the cable clamps. A bad connection there commonly makes power die when you turn the key, even though the radios and lights are working. The big load of trying the start the motor makes the poor connection give up, even with a fully charged battery.
Ive had people tow cars into the shop before, just to twist the battery post clamp around a bit and start the car right up. It happens fairly often...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
