Sulfate
    Sulfate
    I don't know if I'm spelling that right. It's that foamy crap that builds up at the terminals of car batteries. The CV gets it pretty bad and I don't know why. Is there any way to prevent it from forming?
    clean the posts good and coat with something like vasoline... (i use paint sometimes) also tape a few pennies to top of the battery and corrosion buildup will go to the pennies instead.
    Addicted to 86-87 Panthers
      there is a battery terminal cleaner and a seperate spray protectant that i use on all of my cars and on my boat, so far it works really really well.
      What happened here?
        wal-mart uses the corrosion stuff... i have still seen corrosion on batteries that were treated. unless you keep engine area cleaned and also depends on the area you live.
          i seen car batteries in autozone being sold with corrosion on top of them already.
            i have seen car batteries in autozone being sold with corrosion on top of them already.
            fixed that for you.
            Neutralize it with a mix of baking soda and water. Once it stops fizzing, rinse the battery off with clean water and be sure to get any acid or baking soda residue off the battery tray and the surrounding area. Once its clean, you can use some of that protectant stuff, or just dielectric grease or whatever to prevent exposure to the air. I'd also suggest making sure the battery isn't overcharging, since that can cause the acid to boil out of the battery like that.
              thanks
                one tidbit about the pennies, make sure they are pre 1982. It sounds silly, but newer pennies arent made out of copper anymore. They are zinc with a thin copper plating. Once the plating is gone, so is your protection from corrosion.
                Instead of tape, try a spot of superglue, or contact cement. Put one penny next to each terminal and they will act as sacrificial anodes. In other words they will corrode, and your terminals will stay nice and clean.
                Axle codes
                Open/Lock/Ratio #
                G / H / 2.26
                B / C / 2.47
                8 / M / 2.73
                7 / - / 3.07
                Y / Z / 3.08
                4 / D / 3.42
                F / R / 3.45
                5 / E / 3.27
                6 / W / 3.73
                2 / K / 3.55
                A / - / 3.63
                J / - / 3.85
                  these made in china battery cables and terminals have inferior lead terminals
                    I have found that the felt washers actually do work, as long as you get the kind that look like they've been soaked in goo, and not the dry kind.
                      Thanks for the advice guys. I have those dry felt washers on there right now, but I will try to get those gooey washers. I will also get some grease or vaseline.
                        I mainly use dialectric grease, but vaseline also works well. Every so often I use the post cleaner brush and put some on and it keeps them nice and clean. When it used to get gunky we'd used the baking soda method.
                        1986 Grand Marquis LS 2 Door
