Amp light is always on
    Ever since I bought this car the amp light has been on. The battery was tested and it's good and is only a year old. The alternator (2g) also tested good and apears to be new.
    I started digging into the wiring for it today and found that the white/black thin wire on the plug with the orange/black charge wires was cut inside the harness and covered with electrical tape and loomed over. I reconnected it but that didn't change anything.
    So according to this post, http://www.grandmarq.net/vb/showpost...9&postcount=14 the green/red wire is supposed to be the wire that runs the amp light. It seems to be in good shape and runs into the main harness that atatches to the fuse box under the hood. After that I'm not sure where it goes. Does it ground out somewhere? If it does is it under the hood or the dash?
    Thanks.
    1990 Lincoln Town Car 5.0 H.O.
    The circuit runs from the ignition switch, through the AMP bulb, to the red/green wire under the hood. The alternator actually provides the ground to make the bulb go. See if the amp light is on with the regulator unplugged. If it is, there is a short to ground in the wiring somewhere. If its not on, then the issue is something involving the alternator or it's wiring.
    Check the fuse links for the alternator too. Easy way is to take a voltmeter or test light from ground to each of the black/orange wires and to the yellow wire on the regulator plug. Each wire should show battery voltage. You can do this with the alternator unplugged. Car shouldn't be running for this.
      I drove the 91 around for about 8 months with the battery light on... my volt meter showed it was still charging so I kept driving.
      Only after those many months did I notice the charging voltage start to drop lower and lower, so then I replaced the alternator - no more light.
      Weird stuff happens...
        The first 3g on my car did that, it charged but the idiot light was on. Exchanged the alternator under warranty, no more light. Don't know what the problem actually was but it was in the alternator.
          i went thru 4 reman 2g's in 6 years before i did the 3ag conversion
            Glad that old post is still proving useful.
            I just realized, I know the switched +12 is needed to energize the field coils (not knowing this once caused me a whole lot of trouble a few years back), but I have no idea why the alternator light isn't lit under normal operation! Obviously, the normal current draw through it is very small, but why?
              The bulb is bypassed with a resistor to keep it from lighting up normally. When things aren't working, the VR pulls enough current through the bulb to make it light up. Never dissected a regulator though so I'm not sure exactly how it functions internally to explain why this is.
                Huh, put that way it sounds like the resistor must have lower working resistance than the bulb... seems odd in a way, since those diagrams seem to have it labelled "510 Ohms". I suppose I could always just measure one to find out!
                  bulb resistance changes with heat, so that may not give you what you're after. Also, just having a resistor across the bulb doesn't mean current bypasses the bulb totally, it only needs to have a low enough current draw to not cause the filament to glow. In paralell, the resistance is always lower than the lowest single element in the chain. Formula is R1 + R2 / R1 * R2
                    I unplugged the regulator and the light is still on. So tomorrow, while i'm swapping intakes, injectors, and the comp, I'll test the links for the alt.
                      well if you unplugged the regulator (small plug) and the light is still on, you have a wiring fault somewhere else. With the regulator unplugged, there should be no current flowing through that bulb.
