Well Vicky killed another computer. This is the 4th one she's went through since I've had her. She has had computer issues in the past but I guess the rebuilt one lasted as long as it could. That was the first computer she ate when I had her. She then went through one from the junkyard. Then I got another one from the junkyard and it lasted quite a while. And she killed this one last Thursday. On Friday, I installed the last computer I had, and it worked for the day. On Saturday that computer met it's fate. All the computers do the same bullshit. Runs rough, smoke out of the tailpipe, no output from the computers though. But with any of the computers, I could get them to work again by starting the car, then when it's running, switch the ignition to off, and then on again before the engine completely stops. Then the car runs like normal. Also, one time I had noticed that when I drove the car in this state, with the tripminder on, I was getting like 68mpg, so I'm assuming the engine is running lean. Anyone have any ideas why Vicky keeps eating the computers? All help is appreciated. Thanks.
Vicky: The Computer Eater
Tripminder was probably bugging out because the fuel flow output from the computer was off.
Do they fry or just quit working? What kind of wiring changes have you done?1990 Country Squire - under restoration
Originally posted by Tiggie View PostTripminder was probably bugging out because the fuel flow output from the computer was off.
id print out a wire diagram for you car, see where the computer has any incomming power sources and trace them back for anything that might mean the computer is getting too much voltage, a burnt out resistor or something.1989 Grand Marquis GS
