Tach
    Tach
    So I've done a little checking around and some searching on here, but can't seem to find a decent answer.
    I miss having a tach in my car, my last one had one.
    What do I need to get a tachometer to work in a Panther?? I know most tachs use the distributor, seeing as the 4.6 has a COP ignition, that wont work. What are some recommended, more inexpensive tachs?
    1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
    1985 VW Vanagon 70k~
    what year?
        looks like alot of fun..
        * 98+ cars need a tach adapter for tach signal
        * I would recommend an Autometer 9117 tach adapter. FRPP also makes a tach adapter which many have used with great sucess.
        * You will need to wire the tach adapter inline of the factory COP power feed
        o it is a red wire with light green stripe.
        * This is best accomplished at the EEC power diode, which is located on the LH fender well relay block, seen here: http://www.supermotors.net/vehicles/...y/media/305132
        full instructions http://www.crownvic.net/drock96marquis/tach.htm
          Thanks. Wow, that does look fun. lol
