Hey guys, there is a slight coolant smell when the heat first turns on, then it goes away. I am wondering if this means the heater core has a pinhole leak or is about to go.
slight coolant smell when heat first turns on
does your windshield fog up when you first start it up after sitting for a bit?
my guess is yes, ford heater cores are notorious for going bad. the last two fords i have had prior to my current vehicle all started that way. first a small odor of coolant then the foggy windshield.sigpic2004 Mercury Grand Marquis GS
07 P71 dual exhaust h pipe cat back with 24" glass packs Pioneer DEH-P6000UB HU Infinity 2 way 6x8's, Oz Audio 5x7 2 ways, Fultron Tweets, Infinity 1211a and Alpine type R 12"
1999 vw bug work beater
yeah, sounds like the heater core is just beginning to seep a tiny bit.86 Lincoln Town Car (Galactica).
I believe my brother is having the SAME issue! The windshiled fogs up renderign the defrost utterly useless....
Is there any good writeups on how to approach fixing this? I tired to look all over this sight and couldn't find it!"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Basically the long and short of it is that you replace the heater core. What year and kind of car? The specifics change a bit over the years.86 Lincoln Town Car (Galactica).
