3G alternator swap for $20.00!!! Done
    I found me a nice little 1994 Merc Sable at the junk yard. The hood had not even been opened yet. I paid $20.00 for the alt. They tested it for free at the local parts house. And I just swapped it in like it was OE. It solved MANY or my electrical problems. Check it out.
    Vehicle: 1965 Pontiac Catalina (fastback 2+2)
    Chasis: 1982 Ford LTD Country Squire
    Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
    Big Brake swap and front suspension completed.
    Cant beat that for $20!!!
    Looks like you have a large case 3G, but someone's already modified your alternator bracket sometime in the past...
      Amazing what the right voltage will do for you. Is that a new charge cable, or did you cheat and steal the one from the Sable like I do sometimes? Did you grab the 175 amp fuse for it too? I usually rob the parts off the cars simply because I can't get cables that fit exactly right without changing the ends, and I can't do that for less money than I can get the cable for at the junkyard.
        Yeah, I do need to upgrade the cable. Thats one I had laying around. Its a power cable for the house made to be buried for like a well pump or something. I should have taken the sable's wire though. I have the mega fuse, but It all needs some cleaning up.
