automatic fan thermostat problems
    I am trying to install the Hayden economy thermostat for Anabelle. I have it hot wired to the batter terminal now, the only problem is the fan stays on way to long after the car is turned off. I need some way to kill the power when the ignition is not on. I tried the coil ignition wire but when the fan came on it killed the car (surprize) haha. How did ya'll hook up yours?
    are you running the fan directly off the thermostat, or are you using a relay? It should be on a relay, those controllers handle only a small amount of current. Mine is wired off the igntion coil and operates the relay, which is only a tiny amount of current.
      Use a relay. I ran mine to the fuse box, works with the key.
        This is my set up. I used a relay for each fan and ran all the power into a fuse box first and then to the relay, then to the fan.
          oh crap I'm running it directly right now. I'll get a relay and wire it to the fuse box then. Thanks yall.
            Make sure you run the actual power feed from the battery. Only the relay should be powered off the fuse box or ignition coil. You don't want that load on the fuse box, the power feeds to it are not very large, and probably won't handle the load of the e-fan without burning out the fuse links.
              So basically: Battery - Relay - Fuse box - Thermostat - Fan ?
                I think this is what you're after
                Everything to do with interior and body electrical including headlights and tail lights. CFI specific discussions and AC/heating systems.
                Thats for a 2 speed thing. Just get rid of that top hi/lo relay. Use the output from the lower relay direct to your fan. The manual switches are optional and not neccesary. Also I realized i screwed up on the diode part, its a 1N4001, but pretty much any black silicon type rectifier will work fine. The specific type is not important, just as long as its not one of those glass jobbies.
                  Cool man, thanks!
                    Ok, I just bought a 4 pin 40 amp 12 volt relay for $6.99 at Advance Auto. Is this the kind of relay I need for this application? Also what is the diode for, don't those change AC to DC?
                    From reading up on this so far, the Battery goes to the 30 on the relay, the 87 goes to the fan power, the 86 goes to a ground, and the 85 goes to the thermostatic control module I bought with the kit, then the thermostat goes to the ignition source such as the ignition coil.
                      relay is fine. The diode is to keep the AC compressor from kicking on every time the fan runs. Its a one-way electrical valve, which is why you can convert AC to DC with one.
                        This is how I did it. I used the cheap Hayden thermostat, it has two wires and a temp. probe. It is just a adj. on off switch. One wire I ran to the fuse box inside the car. I hooked it to the Auto Lamp fuse and it works with the key. The other wire I ran to the relays to turn the fans on and off. I have two fans so I used two relays. I added a fuse box under the hood (one fuse for each fan), ran the battery power to it then to the relays, from the relays to the fans. I stuck the probe into the rad. and that is it. It has been working fine for about a year now. The fans come on at 200 - 210 and go off at about 185 - 190. I didn't run the A/C with this set of fans, I added another fan in front of the rad for it. It runs off the A/C switch and has it's own relay and fuse. It kind of over kill just to turn a fan on and off, but what the hell it works.
                          All done! everything works great now, I just followed Thain's diagram and re-drew it to my own application and it all worked out. I ran the light load from the relay to the fuse box where there was already a metal tab sticking out of the fuse for the radio power. Now all thats left is a manual switch that jumps the relay and thermostat incase one of those fails and I have to force the fan to come on. w00t, thanks ya'll.
