vacuum
    vacuum
    how do you check engine vaccum and what should the vacuum be on a
    87 cv 302 sefi
    should be about 20 idling
      17" or better is spec. 20 is really super, but you'll only get that on a very healthy motor.
      I disconnect the line to the evap purge solenoid near the battery and connect the vacuum guage to that. Its a decently large diameter hose that goes straight to the manifold. Its about as accurate as it gets.
        what he said.....i've seen em as high as 22 and as low as 7
          I like the McCain Palin sign.
