Hey I have an 85 crown vic with the 5.0 and recently it hasn't been idling very well, it would idle very low, just enough to keep from stalling and today I go out and start it and it wont idle at all, but if I give it gas it will run but as soon as i stop it stalls. What could be causing this?
car wont idle?
you have a vacuum operated throttle stepper on your car that is activated electronicly.
Mine would do the same thing, idle very low sometimes, sometimes not. I replace both the stepper and the solenoid many times, to no avail. FInally I hooked up the solenoid to a switch, and flipped on the idle stepper manually whenever it wanted to idle low.
I finally fixed it recently by converting to SEFIPete ::::>>> resident LED addict and CFI defector LED bulb replacements
