i installed an autometer electrical temp gauge today... my temp seems very low esp considering how hot it is around here.. it stays between 165-170 after 20 minutes of city driving... is this low? should i be concerned?
electric temp gauge
I consider that a good thing. My old 84 stayed around 190, but it never got over 195. Do you still have good heat when you turn the heat on? If not you may need a higher thermastat, if you want to stay warm during the winter.
stock thermostat is 195. I've found that my car behaves much better (better power, mileage, etc) when it's right up there at 195 or so. Before you go fucking around with the thermostat, make sure that the gauge you bought is accurate by using some hot water and a kitchen thermometer. Water gauges have been known to be inaccurate.Originally posted by gadget73There is nothing more permanent than a temporary fix.
my car always runs around 205-210. it may go reach 215 with the ac on i have a mechanical supro gauge
Originally posted by 88_Marquis_302 View Post215 with the AC on? I would lower the t stat in it. 215 sounds kinda high for a 5.0. Just my opinion
my sunpro mechanical temp gauge usually always matches whatever temp T-stat is in at the time.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I have a 195. It runs at 195-200, with the AC. The fans come on at 200-205 and off at 195. When I first start it in the early AM it will go to 205-210 and the stat will open and drop to 190 and settle in at 195. These cars will run better at 195, if it is too cold it will dump more fuel to warm it up.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
